| 883 réponses 9259 vues |
[_- FORD dit OUI -_] Nouvelle Focus RS - Focus RS8 inside |
| agron25 | posté le Lun 24 Dec 2007 à 11:59
La RS avait un autobloc la ST non au lieu d ameliorer ils ont regresser |
| marko | posté le Lun 24 Dec 2007 à 12:00
D ailleurs , je ne comprend toujours pas pourquoi , ils en ont pas foutu un d autobloc sur cette st |
| zlackie | posté le Lun 24 Dec 2007 à 12:06
2 mondes "commerciales" : ST : Tout public RS : Fans sportifs de la marque. D'ou mes interventions sur le 2.5 T, excellent mais pas Ford. |
| ocean_orgy | posté le Jeu 24 Janv à 07:09
How fast will the new Focus RS be? The production model's output is still being calibrated at a figure somewhere north of 280bhp, but it's likely to be governed at the 155mph. Expect it to achieve 0-60mph in under six seconds, aided by an extra-trick electronic front diff that puts the power down better than ever in a seriously powerful two-wheel-drive car, and 0-100mph in around 12-13sec. In summary, we’re looking at Jaguar XKR performance, which is highly impressive at the price. What have they done to the engine? The 20-valve, 2.5-litre, five-cylinder turbo engine comes straight from the 222bhp Focus ST, but it gets modified pistons, cams and valve springs, a bigger turbo, a larger intercooler and modified electronics to produce its 280bhp. Why doesn’t the RS have four-wheel drive? For reasons of weight and cost, but also because engineers believe it’s not needed, despite the high power output. The Ford group does have a four-wheel drive system – already fitted to some Volvo S60s – that could be adapted, but it would add at least 150kg to the car and cut its power-to-weight ratio. Ford is still debating whether to use its six-speed PowerShift gearbox (the equivalent of VW’s DSG system) in the car. Donc définitivement deux roues motrices d'après Autocar |
| xu19tdi | posté le Jeu 24 Janv à 07:37
Va falloir un auto bloc, déjà sur la mienne et sur la flotte, impossible de passer plus des 2/3 de la puissance au sol |
| Rod350Z | posté le Jeu 24 Janv à 08:00
Bref, en relisant le tout premier post du topic, les mecs d'Autocar confirme aujourd'hui ce qu'ils disaient il y a pres d'un an : 280ch, FWD only... Sont fort Autocar. |
| thomas02 | posté le Jeu 24 Janv à 08:44
Avec un DGL quand même !!! Maintenant il n'y a rien d'officiel de la part de Ford, je pense qu'on en saura plus vers le 2ème semestre 2008, après la sortie de la ST restylée (printemps 2008) ! Dernière édition le Jeu 24 Janv à 08:46 par thomas02, édité 1 fois |
| xu19tdi | posté le Jeu 24 Janv à 09:06
Rien à genève vous pensez!? |
| thomas02 | posté le Jeu 24 Janv à 10:34
Non trop tôt à mon avis !! Y en a un à Paris cette année ? En Septembre ? Si oui dans ce cas c'est plus probable ! |
| ocean_orgy | posté le Jeu 24 Janv à 10:41
Ce sera à Londres en Juillet |
| Toniciano | posté le Jeu 24 Janv à 10:52
Ta BmB a un différentiel libre Xu, en terme de motricité, ça n'a rien à voir ! Mais bon, DGL ou pas, faudra évidemment pas mettre pied dedans en 1è sur le mouillé non plus, évidemment. |
| zlackie | posté le Jeu 24 Janv à 10:54
| xu19tdi | posté le Jeu 24 Janv à 13:15
Toni => merci, mais je sais |
| Zorgol | posté le Jeu 24 Janv à 13:19
280ch sur les roues avants... Va falloir prévoir un budget pneu conséquent! |
| zlackie | posté le Jeu 24 Janv à 13:22
Quand on aime on ne compte plus |
| thomas02 | posté le Jeu 24 Janv à 14:01
En même temps on ne fait pas une spéciale de rallye à chaque fois que la voiture sort du garage !!! |
| Toniciano | posté le Jeu 24 Janv à 14:23
J'avais envie de te le sortir quand même Xu |
| xu19tdi | posté le Jeu 24 Janv à 15:01
Toni => t'as bien fait mec! |
| xu19tdi | posté le Mar 04 Mars à 07:48
ça va être de la folie cte caisse! rappel de la carte de visite => DGL + 280ch + 40Mkgs ![]() |
| marko | posté le Mar 04 Mars à 08:07
On signe ou ???? |
| thomas02 | posté le Mar 04 Mars à 08:12
Même si c'est bien sympa comme ça à mon avis ça ne sera pas tout à fait ça ! C'est une ST restylée avec des jantes agrandie à 19 ou 20", des prises d'air sur le capot (style escort cosworth A mon avis ça manque de largeur au niveau des ailes, les jantes seront complètement différentes plus typé rallye asphalte, un petit système Haldex comme sur le Kuga qui est basé sur le chassis de la Focus et qui sait peut être la new boîte Powershift Pour ce qui est du kit carrosserie celui présenté là me va assez Dernière édition le Mar 04 Mars 2008 à 08:18 par thomas02, édité 1 fois |
| badaboombabar | posté le Mar 04 Mars à 08:14
DGL ou pas ca fait beaucoup trop 40mk pour une traction |
| thomas02 | posté le Mar 04 Mars à 08:18
Y a combien sur la Mazda 3 MPS parce que ça a plutôt l'air de passer correctement ! |
| xu19tdi | posté le Mar 04 Mars à 08:25
38 sur la mps |
| zorglub007 | posté le Mar 04 Mars à 09:24
Et puis ils ont mis le volant du mauvais coté ! les cons |
| vassim | posté le Mar 04 Mars à 09:32
2 ans pour un tuning, sont pas pressés les gars. Elles sont ou les 2 autres roues motrices ? |
| xu19tdi | posté le Mar 04 Mars à 09:43
Vassim => à ton avis!? t'es à ce point déboussolé de rouler en ariel!? |
| vassim | posté le Mar 04 Mars à 09:48
Avec ford champion du monde des rallyes elle se doit d'avoir 4 roues motrices ! C'est vraiment n'importe quoi ! Y a plus que les japonais qui savent faire ? |
| marko | posté le Mar 04 Mars à 09:51
a plus que les japonais qui savent faire ? c est a se demander |
| thomas02 | posté le Mar 04 Mars à 09:52
Qui savent faire quoi ??? Des voitures tunées à fond comme l'Impreza et l'Evo !! Oui je te l'accorde ! |
| kri | posté le Mar 04 Mars à 13:53
C'est sur ca peut paraitre tunée une impreza, mais tu n'as pas bien regarer la photo de cette RS Au moins l'imprezza et l'evo assument leur sportivité, la ca devient la course a un CV surevalué, (des chiffres pour faire bo sur le papier et attirer le djeuns en mal de virilité) mais faut voir ce que ca donne en utilisant l'outil pour faire ce a quoi on le suppose destiné |
| marko | posté le Mar 04 Mars à 15:43
mais faut voir ce que ca donne en utilisant l'outil pour faire ce a quoi on le suppose destiné si c est comme l ancienne RS, et bien ca va carrement |
| zlackie | posté le Lun 28 Avril à 16:27
Les dernières rumeurs (avril 2008) la font apparaitrent avec une .............transmission intégrale.......et......au dessus de 300 cv voir dans les 350 cv http://news.caradisiac.com/Ford-Focus-RS-350-ch-et-une-transmission-integrale-953 |
| Rod350Z | posté le Lun 28 Avril à 16:39
J'ai l'impression que le S de RS, c'est pour speculation. J'espere que d'ici 6 mois, ils vont pas nous annoncer une propulsion. |
| marko | posté le Lun 28 Avril à 16:40
Si c est vrai, le top serait qu il n y est pas d abs, esp et toute ces truc electronique par contre, 350 cv, je pense qu il faut prevoir un petit budget pour s amuser avec ca |
| zlackie | posté le Lun 28 Avril à 16:45
N'empêche qu'elle sera dévoilée en Aout 2008 et on sera fixée. Elle pourrait faire un gros coup médiatique dans cette configuration, histoire de vendre plus ses autres modeles. En tout cas, des 2.5 T, j'en ai vu souffler à 320 cv |
| mickdu78 | posté le Lun 28 Avril à 16:57
Ouala je viens de comprendre le message sur le topic de xu |
| agron25 | posté le Lun 28 Avril à 16:59
Si c est vraiment reel ,ca peut faire tres mel en effet est serait bien interresser aussi mais sa serais plus dans les 300cv a mon avis a voir |
| Hasta | posté le Lun 28 Avril à 17:00
Elle pourrait faire un gros coup médiatique dans cette configuration pourquoi? ça existe depuis longtemps chez sub et mitsu des caisses de 300cvs et transmission intégrale la puissance? 350cvs ça reste à voir restes aussi à voir le chassis son efficacité et là pour que ça soit aussi évolué qu'une mitsu ça va être dur |
| agron25 | posté le Lun 28 Avril à 17:02
Hasta ford a l experience aussi mais sa seras surtout dependre du budjet de la voiture qui va faire top ou pas top au niveau de la transmission car un chassis d escort cosworth dans son temps n avait rien a envier au sub et evo d origine |
| Hasta | posté le Lun 28 Avril à 17:04
Dans son temps mais qu'est ce qu'a pondu ford ces dernières années en grosses sportive? la focus rs de 215cvs c'est léger je les vois pas passer à 350cvs d'un coup, faut une boite un moteur un chassis capable de digérer tout ça, tout ça a un prix canon si ils veulent en vendre quelques unes |
| zlackie | posté le Lun 28 Avril à 17:04
Le 2.0 litres de la Rs Wrc développe 300 cv, c'est tout a fait possible de tirer + sur un 5 pattes de 2500 cm3. Mon impatience, c'est quel moteur vont ils vraiment mettre dedans !! |
| Hasta | posté le Lun 28 Avril à 17:07
Faut que ça soit fiable zlackie, un modéle wrxc n'a rien à voir avec une bagnole de série d'ailleurs je dirais qu'avoir des chevaux c'est pas le plus compliqué pour un constructeur, c'est tous les éléments autour qui doivent être à la hauteur |
| marko | posté le Lun 28 Avril à 17:15
Le 2.0 litres de la Rs Wrc développe 300 cv beaucoup plus que 300. mais bride a 300cv |
| zlackie | posté le Lun 28 Avril à 17:16
L'entretien plus poussé est déjà "de série" chez ses rivales, on parle de sportive, pas de la révision vidange à la clé d'un Tdci tout les 25 000 Sinon, le 2.5 T5 de la S60R, est très fiable à 300cv, y'en a même d'occaz à 300 000 kms au compteur. Pour le chassis, je m'en fais pas, la transmission un peu plus, même si elle existe encore chez Volvo depuis longtemps. En fait, j'ai peur que la RS soit une S40 RS jamais née. |
| agron25 | posté le Lun 28 Avril à 17:17
Hasta leur 5 cylindre ca fait deja un long moment qu il est eprouver il est sur les volvo a 300cv d origine , est ca fait deja bien longtemps donc les 350cv sont envisageable ,mais niveau vente je pense pas que sa soit fesable car avec une transmission evoluer ca va revenir a trop chere si ca reste dans les 45ke 350cv et 4RM sa risque d se vendre quand meme pas a la chaine c est sur mais sa se vendra surtout chez les englais |
| zlackie | posté le Lun 28 Avril à 17:18
beaucoup plus que 300. mais bride a 300cv Camarade me comprend, ouf' |
| Hasta | posté le Lun 28 Avril à 17:20
Toute façon ça reste du paluchage si ça se trouve au mois d'aout on va apprendre que ça va être une merde de 250cvs sans autobloc en traction les rumeurs à la con de Caradisiac sont loin d'être sûres à 100% |
| zlackie | posté le Lun 28 Avril à 17:21
Agron>Je vois la bête ne pas dépasser les 40 Ke !! |
| agron25 | posté le Lun 28 Avril à 17:25
Hasta sa se pourrais aussi faut attendre pour etre sur zlackie je doute que sa fasse 350cv 4RM pour 40KE quand meme |
